A better look I'm the day time. Spent all of 15 minutes doing a rough trim to get thr fender to clear the bumper and see what challenges lay ahead..
I'll definitely be adding material to close off the fender to door gap. Don't see a way around it. The rest of it roughed REALLY close so I don't see what I could adjust to bring that in more.
Otherwise, if I cam get anywhere near this fitment when said and done, I'll be ecstatic.
My plan is to be able to use the factory tacoma hood latch, but if that doesn't work to close and latch as perfectly as it sits now I'll just cut in my aerotech flush mount hood latches, though I domt want to.
Next step will be to finalize the headlight wiring and start making brackets to lock thr headlights in place, then lock thr grill in place, and then hopefully dial in the fender fitment.
Once I am more or less happy with how it sits I'll address the door gap. I already have the resin and fiberglass material so won't be an issue, but will definitely add a solid day of work.
Sent from my SM-G970U using Tapatalk
