Originally Posted by phatcheeks
I have a non sealed v6 with aux cooler. Instead of using the original return line from the radiator, can I use the return line from the aux cooler to drain the fluid? If I use the original return line from the radiator it will bypass the aux cooler that way. Not sure which way is best.
Then I can refill from the dipstick
yes you can use the return line from the aux cooler, either way will work.
