The biggest 'gotcha' here would be the damping rates. You might find yourself with an unbalanced setup where front or rear is over/under damped compared to the other.
I don't have first-hand experience, but I understand that Dobinson's is very good at suggesting a set up based on use case, so perhaps you can give them a a call and see if they can recommend a setup similar to 6112s or some other option.
In the end, it might not be a huge deal and you might not even feel it, but then again, you might.
