Originally Posted by dcguy
Hello, have you had any water ingress after this type of installation? I see in your pictures that the cable rests on top / in between the rubber gasket and the rear hatch gate, which I assume does not allow the rubber/gate to have a perfect seal while closed.
Also I assume you connected the weboost to the rear power outlet socket, is that correct? Any issues so far?
No water leakage to date. Not plugged into rear power socket but wired to the starter. It shuts off w/ vehicle electronics.
