Originally Posted by ragin_cajun
No one has mentioned it, but I would check your ABS sensor wiring. This is a common issue after lifting if someone pulled on the wiring harness too hard. It could be momentarily triggering ABS or traction control. You shouldn't have a random UCA rub going straight down the road.
If this happens, will there be a light on the dash ?
