I went back to NJ Devils Way this weekend. Nearly all of the snow is gone, so everything's opened up for the little Trailrunner! I went to an area of the woods that I hadn't previously explored. You can see me living on the edge in a couple photos. Beyond that was some downed branches that I originally thought I couldn't pass but found that I could today. There were also other branches further down that I actually couldn't pass. I thought about coming back another day with an axe to clear out the spot, but I decided to see if I could get the truck to go around the branches while I stepped over them. I almost got the truck stuck in one spot, but I successfully pulled it off! This truck is super rugged! It was also high tide at the river, so I got a photo of the truck by the river at the same spot as last week but looking different. I think the only two places I got stuck were the branches that I took the wide path to get around, I tried attacking them head on my first pass, and going down the curb into the parking lot. There was loose, sandy dirt behind the curb, so when I eased down on the skid plates to get my front wheels down, they actually got stuck up in the air while the rear wheels just spun in the sand. I had to give it a little kick to get it going. So embarrassing! Just a little way over is some grass, so I'll have to remember to hit the grass next time.
I also used my 3S lipo again this time. I actually can't remember the last time I used the 2S. The 3S is great. It doesn't go too fast if I remember to exercise throttle control, and I get a bit of extra speed in case I need it where the 2S would fail to climb or get over obstacles. It's also a larger 3S, and I have aluminum hub adapters. I don't know if I can get the weight any better. I'm so happy with my current setup. And while the hub adapters are aluminum, they're not too heavy, so the rotating weight concerns are a lot less.
I think I'm going to go somewhere else next weekend since I've gone to NJ Devils Way two or three times in a row since the weather started getting nicer, but I'm looking forward to going back in the future. It's a lot of fun here.
