I rescued my 4runner from a dealership about two years ago so I can speak from my experience only.
If it is running good (smooth idle, etc) I'd just do a good oil change on it, and an intake filter. I went with Napa Gold on the filter.
First thing you should do I check the age of the radiator. If it's the original, replace it with a new quality one. I went with the expensive Toyota OEM one from the dealer.
Also LBJ should be inspected by someone with enough experience to determine their condition.
After all that checks out, I would set aside a couple of hundred for future unexpected stuff.
After that see where your budget sits. Maybe you get out cheap and still have $2000.
Tires and a decent lift will blow that very quick.
The rack will probably have to wait, but at least you got the maintenance stuff done, and the lift/tires will get a 3rd gen pretty much anywhere you wanna go.
You can also just select the shocks/struts you desire and run some used coils from a FJ or 5th gen for a while to give you enough room to clear 32's, and freshen up the suspension.
2016 TE (WIFES)>Stock with KO2's, SW sliders
2001 Sport (MINE)>FJC front coils/C59-137 rear 5100's, 265/75r16 g003
2013 Mazdaspeed3 (MINE)> bolt ons and tune
