View Single Post
Old 03-18-2021, 09:07 PM
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
** Enter at your own Risk!!
{UNPLUG BATTERY Ground - wait 15+ mins., surf T4R.org}
The Seat Warmer Green Wire....
Ends at the IC4 connector as mentioned by others...
---> To add a female pin to the connector.
The IC4 connector consist of FOUR separate connectors, connected together.
IC4 needs to be unplugged, the specific connector unlocked, and removed from the cluster.
Once the connector is removed you can get to the lock on the connector to install the female pin.
{The blue, yellow, and gray connectors were removed to get to IC4}
Thanks to the T4R folks for the motivation..
Wiring for heated seats and diagram for power seats-20210318_201922-1-jpg  Wiring for heated seats and diagram for power seats-20210318_205318-jpg
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
