Yes, the SR5 and the TRD Off road have the same metal skids. The OEM skids are just fine. Sliders area better first armor choice, IMHO. For aftermarket, I like RCI's raw aluminum skid. I used the stock skids on two 4runners and got an RCI for the low 4th gen.
The stock "skid plates" are in two pieces. Most after market skid plates replace both stock pieces with one piece. Sometimes its nice and easy to have them separate. Stock skids are easier to remove for some people. The front skid needs to be remove to change the oil filter. The "other/2nd piece" stock skid plate has a removable plate to access the oil drain. The second stock skid plate usually doesn't need to be removed for oil service. I let the front one hang, instead of removing it when I need to access the filter cartridge.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
