Originally Posted by perf0rmance
Did you simply replace the OEM spring with a taller spring? If so, I'd argue that this is the proper way to get a suspension lift.
I did the same upgrade with my 2017 Pro - replaced the OEM spring with a taller spring (fronts).
Yes. The Eibach springs replace all four which I know the Wescott uses a spacer in the rear. I also think replacing coils would be the proper way.
