View Single Post
Old 03-24-2021, 11:21 AM
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
One thing you can do: get a can of brake cleaner. Remove your skid plate if necessary, then spray the area where you see the fluid, plus a little bit above that. Spray a lot to get as much grease off as possible, then let it dry. It should LOOK dry when you're done. Then start the truck and observe the area you sprayed. When you start to see any liquid, it should point you in the direction of the leak.
thennen is offline   Reply With QuoteReply With Quote
