Originally Posted by KingPrat
1. Yes, and the adaptor comes already connected, you can see it on the left side of my first picture. Has a blue label. The USB port in the dash stack runs CarPlay.
2. Yes I did. You'll need to update your Sirius account to the new radio ID # once you get it all installed. I believe there was a cost associated to do that w/ Sirius, but I don't remember how much. No need to run the new antenna, they will include the adaptor to use factory connections.
A quick note on #2 - there are two IDENTICAL plugs behind the dash, at least there was behind mine. There is one that comes down independently from the upper dash/behind the clock. I'm now almost positive that is for the compass/navigation, and is NOT Sirius. The plug you'll use is in the factory wire loom w/ other radio connectors, believe it's a black connector IIRC.
I spent over an hour on the phone w Sirius before I realized I was an idiot.....
Thanks
I've been trying to convince myself to upgrade to a CarPlay headunit for a while now, this company's service is exactly what I needed to push myself over the edge.
