Originally Posted by zw470
1. Did the kit come with everything needed to make the factory USB port work with the new radio?
2. Did you select the "maintain Sirius/XM" option?
One word of advice with updates to the headunit, the AX7000 has two USB's on the back. Assuming you ran the primary USB to the existing plug. I would recommend running the other to an easy to access location. All updates so far have required you to download the firmware from Sony's website, load them to a USB stick, and then to update via both USB plugs. Start on the primary, then finish the install on the secondary USB. In my 08, i just ran an extra usb extension into the glove box. Good support so far with Sony updates
