Thread: Long Crank Time
View Single Post
Old 03-29-2021, 09:00 AM
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I'd also recommend checking the power wire to the starter for voltage drop while cranking. You may have high resistance in that wire causing a slow crank. If you haven't cleaned your ground connections in the engine bay now would be a good time to do that as well.
