Originally Posted by Mgltacoma
Do you refill them with distilled water? My Panasonic battery screw on gas cap looks to be sealed, slightly different than older OEM Panasonic batteries. I might be wrong. I will need to post a pic of it here.
I have not had to add distilled water yet on my 19, but I do check levels. FWIW, there are 6 screw-on caps on my stock battery. It looks like this: You can see the six gas relief / fluid fill caps.
Incidentally, I have the same Noco Genius 5 as you. But I also have a battery meter, so I check voltage and charge level before hooking it up. Noco's product information says it has overcharge protection, but I have seen other's argue that point so I'm not sure what to think about that.
