Originally Posted by BostonJon
The secondary air injection system is a problem on the Toyota 2uz-fe V8. If it’s not currently failed or failing, a bypass can be purchased and installed for $50 and about an hour of your time so I wouldn’t let that scare you unless there are current codes indicating the system is failing.
Exchanging the fluid in the trans pan is relatively straight forward. You can also do a more robust fluid exchange using the trans cooler lines. Neither approach requires you to drop the pan unless you wanted to change the filter.
Excellent, thanks. Good to know there’s a bypass. Too bad there’s no dipstick tho, I’d still like to check the fluid.
