View Single Post
Old 04-08-2021, 10:22 AM
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Lifting an Independent Suspension does not allow for bigger tires. The geometry of the suspension is unchanged - it will travel in the same arc and start/stop at the same points.
So yes, 285/70R17 will fit a stock TRD Pro, *but* you will have to modify the front fender liner and possibly modify/remove the front mudflaps. If you change wheels or add wheel spacers you may contact the Body Mount or the plastic cover behind the mupflap that hides the pinch weld or even the pinch weld itself.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
