Hi everyone,
I’m new to the 4Runner family. Have a 2021 TRD Pro.
I wanted to add smoked amber raptor lights but I’m not electrically savvy.
1) I want the ability to turn the lights off but without having to install a relay. Is it possible to link the Raptor lights to DRL and Headlights? That way when I have either my DRL, Low Beam or High Beams on, the raptor lights are on? And when I have the DRL off (and lo and high beams) the raptor lights are off?
2) I see that if I add a fuse to the cabin fuse box, the fuse cover won’t fit. Is there another fuse cover that is 3rd party that could allow the fuse box to be covered with the added fuse?
3) I’m also in the works of installing Thinkware U1000 front and rear dash cam via OBD2 power cable instead of hardwiring it in. Where do you guys recommend the excess cables for the front and rear cams be tied up and hidden? I had seen the side of the dash on some other cars being popped open and those going in there. Is that possible on the 4Runner too or is there a better spot?
