View Single Post
Old 04-09-2021, 12:33 AM
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Originally Posted by HNTMUP View Post
Sorry, I know this has been ask and answered before but...
1) What 5100’s (front and rear) should I order?
2) I am only interested in leveling out the front so so is it wise to replace my UCA’s when I install the shocks?
3) do I need to replace the OEM springs?
Thank you,
JDG
From my own research I believe these answers are correct.
1. There is only one application of 5100's for our 4Runners. Front p/n is 24-196499, rear p/n is 33-187174.
2. The two most popular 5100 setting combos that I have seen are:
a) 1st notch up lifts front 0.85" and used with no rear spacer pretty much levels it.
b) 2nd notch up lifts front 1.75" and used with a 1" rear spring spacer levels it while also giving a slight overall lift.
Neither requires the UCA's to be replaced. I'm not sure about going higher.
3. No need to replace the stock springs with the two popular settings above.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
