Real Name: Todd
Real Name: Todd
You could always just remove the sway bar. Filter fits just fine without it and handling is fine too.
I run the YZZD3 on my 03 V8 and don't recall there being a fitment issue with that filter before I removed the sway bar.
Just a thought as well. A little more work but you could also unbolt the sway bar links from the spindles and rotate it out of the way.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
