Originally Posted by photoleif
this answer pertains to my '99, and it may be useful to you; not sure if the wiring is the same. the wiring goes through the loom / conduit near the hinge, of course, but i believe it changes color somewhere in that path, which makes things 'interesting' by the time it reaches the thick bundle of wires in the area you referred to, which is directly below the driver's side kick panel fuse block (near one's left knee, approximately). i needed to pulse two leads: green/yellow, and brown/white.
looking at the door lock control schematic (034DLC.pdf) in the FSM, G-Y is unlock, and BR-W is lock. i think that should help you since you could briefly pulse +12 at one or the other (vampire tap or pin or something) and really determine if the switch is getting power, if the lock mechanism is to blame, or if one of those molexes is going wonky on you. i recall from futzing with those molexes in the armrest that both of the main ones need to be connected properly, or some functions mysteriously fail.
Thanks - yes to the molex. I jumped the connections in the molex and it will work if I jump the 'close' circuit, but note the 'open'.
Very disappointed to hear that the wires change colors!!! Not ideal!!
