Originally Posted by daytonaviolet
Great write up ElectroBoy. But I took the easy route and installed the meso puddle light kit. It worked like a charm as it was all plug and play.
Also I added the reverse trigger to it so the puddles automatically turns on while backing up. If you want to give this a try. Just connect pin4 of the meso puddle light kit switch to the reverse trigger pin4 red wire in main body ecu harness.
Thanks OldRed for the trigger wire.
Thanks, that’s a great idea!
I’m looking at the back-up lights wiring diagram and how to wire it into my setup.
I’m wondering if you could check something out on your 4R for me.
When you flip the Meso switch to On, do the backup lights turn On as well as the puddle lights?
