Originally Posted by ElectroBoy
Thanks, that痴 a great idea!
I知 looking at the back-up lights wiring diagram and how to wire it into my setup.
I知 wondering if you could check something out on your 4R for me.
When you flip the Meso switch to On, do the backup lights turn On as well as the puddle lights?
When I manually turn on the puddle lights, the reverse back lights does not turn on. Only time the back up lights turn on is when I知 actually in reverse.
I made my own anytime front - rear camera harness and I had to add bias diodes when ever i touched the reverse trigger. So both front and rear mode has a diode.
If your having that issue when manually turning on puddle lights, are you using reverse trigger ? If so the diode may also be needed.
The diagram below is for the CTH anytime camera switch when used with the T9. But I知 showing this as a diode example.
