Originally Posted by Gouranga
so turns out i was right.. this shaking that i feel in the steering wheel is from the wind........ (PS: i have the venture with the basket so maybe thats why)
today i drove down same highway but no wind and zero vibrations
i believe the wind + basket+ Duelers tires = shakes the car left and right as you drive making you feel the steering wheel shaking slightly left and right
The wind cannot cause you steering wheel to shake. It can cause your truck to wander in the lane and want to pull to either side if the wind is sustained.
The steering shake is very likely a balance issue and even on the same route it's not always apparent. I have noticed that even outside temperature differences can cause the symptoms to either show or not at all.
It will likely present itself again, and when it does take your truck to the dealer for tire balance. I'd put money that you'll notice it again. It's a common thing with these, and mine did the same when new. I had to rebalance.
