Factory JBL box with JL 8w3
I used two separate amps. Then used the audio control line out converter. The bass knob I already had before I added the amp for the door speakers and line out
The focal sound 10 times better amped vs just deck power. The line out has a built in EQ so between that and the factory deck there’s a ton of room for making it sound perfect.
My SR5 has a third row and the holes for the box are already pre drilled. I literally just bolted it in. Super easy
Forgot to add........the panel with the cubby is the exact one I have. You literally just remove the cubby. There’s clips on the back side of it.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
