Do you have a stock front end?
-If you do then that will rule in 880 & 881 for OME.
How much rake do you want?
-If you want the rear to sit about 1" higher then 880.
-If you want the rear to sit about .5" higher then 881.
Do you have height adjustable shocks?
-Gives the ability to fine tune your ride height.
Wheeler's is correct. 890s gave me about 2.5" rear lift (22.5" center hub to fender) & about 2.75" with no cargo load.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
