Originally Posted by AndroT100
How does the handling of the KYB shocks compare to the XREAS? I am at this moment trying to decide which way to go...Bilsteins, KYB, OME, Dobinson, etc.. Really want to keep close to, or improve on, the ride/handling of the XREAS and only want about 1" lift.
the KYB handle very good IMO, they do everything my non leaking xreas did aside from harder corners, the kyb have a little more body roll but thats expected with a mechanical vs fluid coupled system. the way to improve body roll is using poly sway bar bushings to tighten up the cornering. with teh 10% stiffer springs & shock valving of the kyb & poly sway bar bushings you should be very happy with the corner handling & street driving.
