View Single Post
Old 04-17-2021, 04:18 PM
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I still haven’t replaced my pads yet but I’ve pulled the pins and the springs to inspect and clean.
My rotors are still looking very good and I prefer to keep them untouched since there’s no pulsating at all. This is my philosophy on brakes but I’m not recommending for anyone else. When I bought OEM pads I also bought OEM shims. I did buy aftermarket pins and springs but those can be quickly replace if I’m not satisfied.
Edit: I just did my 2015 RAV4 brakes. The pads wore down nice and evenly to about 2mm. The clips and hardware were really like new. Still had some original silicone grease on the back of the shims. I did not use the new stuff I bought. Just pads.
Here are my part numbers if anyone needs them.
Verify with a dealer.
Front Rotor 4351260191
Front Brake Pads 0446560320
Front Shim kit anti-squeal: 0494560090
Front Caliper Pins: 4773560300
Front Caliper Pin hold (Spring): 4774360280
Front Caliper Springs (fitting kit): 0494735050
Front Anti-Rattle Spring: 4774835010 (not needed if using fitting kit?)
Rear Rotor 4243160311
Rear Brake Pads 0446660140
Rear Shim Kit: 0494660141 / 0494660140
Rear Caliper Fitting kit: 0494722050
Do Not Use - these kits
Front Brake kit: 04465-AZ001-TM
Rear Brake kit: 04466-AZ004-TM
ACDelco Springs and Pins 18K2113X
ACDelco 18K822X rear clips
Carlson 13600 Front Brake Disc Hardware Kit
1000MPH is offline   Reply With QuoteReply With Quote
