Originally Posted by lewdog998
I have the newer fox shock upgrade the TSB where they replaced the coilovers with the 21 version. I did not take measurements before, but they definitely sit a little higher than the originals (maybe because they are new...maybe that is not even a factor). They are definitely close though.
Suspension lift height doesn't matter. I'm at 2.75" front with Kings. It doesn't matter because you're 'preloading' the suspension to sit higher. It still moves in the same arc through its travel. So if it's gonna rub, it's gonna rub anyway if you really stuff the tires.
But every truck is different slightly.
