Originally Posted by sean.turner.1238
Oh shoooot.... I'm pretty sure I did that. The plastic harness casing that sits on top of the engine basically disintegrated in my hand like many other people have experienced, so I spent a good hour or so removing it all and wrapping the harness with some of that German high-temp high-tensile-strength indestructible goodness. But that will absolutely be the first thing I check when I get home. Thank you
I will check my wiring colors for you today but I can't be sure they are the same as your 2002. But I am guessing the harness length will be the same, longest wires to middle coil pack. Good luck, hope it works!
