Originally Posted by Gouranga
would this work for non pro but trd rims on a venture for example
Not without raising the front end to the same height as a stock Pro, +1”. You could add a leveling spacer to achieve this, or maybe you can adjust up your non Pro shocks, not sure if you have 5150’s, then trimming your front fender/bumper area per the Pro as done at the port and then pushing in your fender well. I did not do this. There is a TSB out there for this mod and plenty of videos. The rear height is the same on the Pro as the other models.
I added 1.5/1” Cornfed spacers to my stock Pro and did no other mods whatsoever with my 285’s and only slightly rub at max articulation in certain situations.
