View Single Post
Old 04-20-2021, 02:17 PM
swapped_mini swapped_mini is offline
swapped_mini is on a distinguished road
Someone mentioned it earlier, but double check the coolant and air hoses that go to the Idle Air Control valve, you can run coolant into the motor through the intake that way. Be careful because this can hydrolock your motor.
If this is the case, you can pull the plugs and crank the motor over to make sure there isn't enough coolant in the cylinders to cause problems.
swapped_mini is offline   Reply With QuoteReply With Quote
