Ended up taking battery out of fob, taping battery to back of fob...hiding the fob inside....taking the key (that was in the fob) and zip tying it under the frame in an inconspicuous spot. So when i went to CO and NM this last week I would be ok if I lost the set i was using.
so if locked out, ...get under car to retrieve the hard key, open door, find fob, replace battery and you are good to go.
I do find it interesting that there is no way to start the car without the fob. ON my last car with push button start, The actual push button could be removed to reveal a hole that you place the key fob (the end of it) and turn the "key " and it woudl function like an old school key start.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
