View Single Post
Old 04-22-2021, 04:31 PM
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If your sure you don't have any leaks and everything is in good working order.
You can always have it sucked out and pressured down test.
If it can hold a vacuum for a few hours then you don't have any leaks.
Make sure the correct amount of refrigerant goes back into the system.
If I were to do this.. I would replace at least replace the dryer as it keeps the refrigerant dry.
As I blew a compressor once, playing around with the just top it off method. As most independent shops with some size to them have a 134A recharge/ evacuation system that can pull your refrigerant out then vacuum test it down for a more thorough leak test.
Just a thought: Your condenser fins are clean of dirt and debris ?
