Real Name: Leif
Real Name: Leif
we replaced our front valance with a new one. the old one was cracked and pretty wretched. i looked into attempting to fix it, and realized that with the kind of wind it has to put up with, there's really no adhesive that would hold against that vibration. i could bracket and bolt it, and then i'd have ugly bolts showing... so got the new one from amazon and it was a perfect fit. arrived in about the largest, lightest box the UPS guy had ever seen, he said. i told him i bought 4 lbs of air. the exact one i got is no longer listed on amazon, but it sounds like you have located some.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
