Originally Posted by rageandlove
Nice work
@ Röde Orm
Did you end up taking out the top tray as well, or did you manage to do this by just taking out the plastic insert that holds the plug?
And how hard was it to take out the plastic insert that holds the plug? That may actually be a better way to run wiring through that area if it's fairly straightforward (which the top tray is not).
Thanks!
Hello
I just removed the whole tray. It came out with ease. Now that plug has 2 tabs on either side. And as I was removing the old one. One of the tabs broke off. They are really hard plastic. And kind of brittle.
Easiest is to remove the whole tray.
