View Single Post
Old 04-25-2021, 02:03 PM
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Originally Posted by rageandlove View Post
Nice work @Röde Orm
Did you end up taking out the top tray as well, or did you manage to do this by just taking out the plastic insert that holds the plug?
And how hard was it to take out the plastic insert that holds the plug? That may actually be a better way to run wiring through that area if it's fairly straightforward (which the top tray is not).
Thanks!
It's pretty easy to take out the electrical panel. Just a few tabs on both sides using a trim tool. After you take it off you can slip your hand into the opening and use a stubby philips head to undo the two screws on the top tray and simply pop it off. I did this to run wires under the wheel well area. FWIW I put the tray back on but did not screw it back in if I ever needed to access it again. It doesn't rattle or make any noises unscrewed.
Now the driver side top tray that's an entirely different question. I think if you wanted to remove the top tray without breaking tabs you have to remove that entire side cargo panel. If I ever have to remove that entire panel I'll be sure to remove those two screws holding the top tray.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
