Originally Posted by honda250xtitan
IMO any 2.0 is an upgrade. 2.5's obviously would be even better. are you running rubber shock boots over the shaft? you need to be. is your shock length appropriate for your lift height? is it over compressing and blowing it out?
Yep, rubber boots are there. So with my constant rear weight, I’ve measured the rear lift at 2 inches. Which is exactly what Mike at Dobinsons said it would be.
I was curious about the extension of the shock so I measured it. I can’t remember the exact length but the shock at full extension is still higher than the spring at full extension.
Toytec uses the same shocks for their 3 inch lift kits.
