Originally Posted by dezertbomber
Remote resi's also allow for more shock travel in addition to the extra oil capacity and heat dissipation. The foam cells don't help with heat dissipation, just reduce cavitation (forming of bubbles) of the oil.
That said, how are the foam cell pro's on rebound dampening? Do you have HD springs? Any fast faced off roading or mostly just trails/crawling? I'm considering these before just pulling the trigger on Kings.
Like the OP, I drive hard and want something that can handle the punishment.
The foam cells do help with heat dissipation as liquid to metal conduction/convection is much higher than gas to metal conduction/convection. This is most prominent in a twin tube, but even in a traditional monotube or remote resi the gas isn't helping much with heat dissipation. There is also a much greater thermal mass to the oil in the foam cells (they are heavy). And yes, this all aids with reducing/eliminating cavitation since there isn't much gas to come out of solution due to them not being pressurized (except due to thermal expansion and the foam compression).
I've had good experience with extended washboards at high speeds with no fade, where I had previously felt the stock fade in less than a minute. I'm not running the baja or bombing through whoops in my daily. No HD springs. Most of my extra bolted on weight is in the front (skids) and mid (sliders). Drives great and is well planted when I do come across a rogue whoop (not jarring, no bouncy bouncy).
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C |
Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) |
Drawer less drawer system and sleeping platform. |
TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 |
RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former
LT265/70R17 C Duratracs
