Originally Posted by Bad Luck
I would assume the scangauge and ecm temp sensor are good. What does the instrument cluster show if you unplug the other sensor?
I unplugged the rear sensor to the gauge cluster . The temp gauge read normal - smack in the middle and did not move. I tried it with both cluster gauges. Same result.
I also managed to rip the wire out of the paddle connector for my trouble.
I'll add it to the list.
