Originally Posted by gfego1
No stored codes, battery voltage nominal. Using a Sprint Drive device so I can check while driving. Just fine battery in green. I forgot to put that it reset the trip a/b mileage and the clocks. Today it also did it just after it started the car and put it into reverse gear having applied the brake.
Did you ever find out what was going on with this? I had a similar problem this morning on my way into the office. I'm hoping its just a loose cable, but I'm afraid it might be the alternator or the charging circuit.
