Originally Posted by tyler.lewis
Yes I am having that issue right now installing mine. The rental tool at oreillys is too big and hits the spindle. However since I am running the JBA off-road UCA arms which has the ball joint bolted on the control arm, I just need to to install the female end. I think I am going to try using a large socket and a through bolt and tightening it up to see if I can get it to seat. Just ran out of patience using that tool this weekend.
Installing was massively easier. I did SPC arms and the knuckle part was shaped to fit directly in that type of ball joint c-clamp press. Removing the UBJ would be much easier if you cut the stud off, which I didnt do. It's like trying to play tetris eith thede adapters otherwise. The O'Reilly obe I only used as a receiver cup for removal. The large Advance Auto kit had the right size adapter for installing.
