I guess I don't beat my rig's enough.., all these years of fighting to break loose those cam bolts I never heard of these cam eliminators. You can always mark your cams with the provided lines and see if this is actually needed, I keep good tabs on my alignments and this hasn't been an issue even with a Hydraulic plow and winch hanging off the front, and a lot of offroading without plow obv. Must be fun trying to train the alignment tech on how to align your rig since they usually don't touch the cams anyways lol.
