Thread: Tap Size Needed
View Single Post
Old 05-03-2021, 08:16 AM
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Originally Posted by Saker View Post
Skid Bolts are M10 X 1.25
Originally Posted by repo View Post
Re-tapping aint really a thing taps are for cutting new threads. You should use a proper thread chaser/restorer unless the threads are totally wrecked.
Originally Posted by 1000MPH View Post
Found this set on Amazon I didn’t know I needed until now.
Amazon.com: Lang 6 Pc. Metric Thread Restorer Tap Set (LNG-2588): Automotive
Ok, didn't check back on this thread after someone gave me the bumper cover screw size and I wish I had.
Here is where I landed. I ran ( cheap HF ) dies on each bolt (5) @ M6x1 and and I had (4) new bolts for the main skid. Dies cleaned up the bolts, or maybe they just cut new threads, no idea but i kept on going.
Next, I ran the taps (cheap HF) up through each hole. Wasn't real easy or real hard and shavings were coming out. After each hole, I finger tightened a new bolt up into it to make sure the bolt would go. I thought they felt a bit loose, but kept going.
Here's where I'm not to happy. I could tighten 2 of the skid bolts to what I thought was tight enough, but not they other two. They are stripped again. I also found that the bumper cover bolts were similar.
I want to re-tap all of the holes for new bolts one size up. I looked at some tap and drill charts, but I'm confused. Can someone give me the proper method for finding the next size so I can get the skid solid again. I will buy good taps and a good tap handle as the HF tap handle really sucked.
I'm almost ready to just drive some self tappers in there.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
