Originally Posted by NJ-4Runner
... At what temperature will the a/t trans temp light come on. ...
It is a very high number, like others said upper 200s, closer to 300, way too high, hence they call it an 'idiot' light.
Did you pull trans dipstick to have a look at the color? If on just a tiny bit probably won't make much difference but everything affects everything, in a trans anyway.
Might even do a quick drain/fill.
If you have 4x4, I'd use it in 4Lo next time on the sand or going really slow. You can start in 2nd gear and avoid the hard 1-2 shift in 4Lo on 01-02s, another feature!
Luck.
