Originally Posted by Dragon_EX
Is it the bolt on the bell crank that barely touches the drum? I had to adjust those after tightening the nut on the handle. I don't know if it could be the adjustment of the shoes because they got replaced several months ago, not by me but my dad took it to a shop. I definitely don't want to get into taking the wheels off until I exhaust all other options.
Yes.
With the way the system works, adjusting the shoes is the first thing that should be done. You're kind of doing it backwards. You should adjust the shoes, the bell cranks, then finally the handle.
If you don't want to do the work of taking the wheels off, take it back to the shop and tell them your parking brake isn't work right since they replaced the shoes and maybe they'll adjust it for you. For the record, you could adjust the shoes without taking the wheels off, but you do need to get them off the ground. There are lots of posts about this on the forum.
