Originally Posted by Too Stroked
You can rule out the rotors and drums by checking them with a dial indicator. Excessive runout on rotors and out of round drums will show up pretty easily. If they check out true, I'd be looking for loose / worn suspension components - especially up front. Loose tie rods, ball joints or suspension bushings can cause excessive shaking. I'd also check the wheel bearings and the steering rack.
I’m gonna go ahead and rule out the braking system because they were all replaced very recently... under 500 miles ago. i replaced LBJs, inner/outer tie rods, steering rack bushings too. bushings all look okay they’re not falling apart or anything. my steering rack did recently start leaking
