View Single Post
Old 05-05-2021, 11:10 AM
RumHam26 RumHam26 is offline
RumHam26 is on a distinguished road
Originally Posted by Skulking View Post
I found a set of rubber bushings on rockauto. They are labelled as front, and it looks like there are different part numbers for the front vs. rear end link bushings if you go OEM, so you may be out of luck with aftermarket replacements for the rear. That said, the OEM bushings aren't super expensive. You should be able to get all of the end link bushings front and rear for only ~$20 plus shipping.
You're pretty spot on with the price - around $30-35 shipped. I ended up ordering a full set of poly because they were only $10 - Energy Suspension 9.8106G. If I don't like them I will definitely go the rout you suggested. I just figured there should be a source for these cheap little pieces of rubber! Thanks for the help.
RumHam26 is offline   Reply With QuoteReply With Quote
