View Single Post
Old 05-10-2021, 02:52 AM
rjtakesphotos rjtakesphotos is offline
rjtakesphotos will become famous soon enough rjtakesphotos will become famous soon enough
Another day another addition!
Started by tackling the Meso Customs puddle lights. These things look sweet!
Took a few minutes to get the mirrors apart. Sounds terrible when you are undoing it but easy to do.
Swapped the oem lights out for the Meso lights.
Mirrors took a few minutes, then it was onto the wiring kit with the switch. Easy plug and play, hardest part was just tucking the wire under the carpet.
Button added in. While I was in there I swapped some of the buttons around. Took the old wiring harness buttons in and filled them in with blanks. Moved the inverter button up top because it is hard to tell when its actually on from the lower spot. Bottom row will be for the lights.
Wrapped it up within 20 minutes or so, and moved onto the awning brackets. These are what I am swapping out them with. While it worked, it was not solid.
Only have a 6.5' awning, which only needs 2, but since I got a set of 3 might as well use them. Will also be nice since we use the awning room with it, can never have too much support!
Solo mounting it was a challenge. Feel like it needs to be adjusted and slid forward but that's for another day when I have a second pair of hands.
While I was doing that, my kinetic recovery rope got delivered! Now to find where to put it in the car.
rjtakesphotos is offline   Reply With QuoteReply With Quote
