Originally Posted by randy88fj62
Just installed a PML extended aluminum transmission pan. It still fits up enough that skid plates will cover it.
Now that the extended one is hanging a little deeper I am concerned it can get hit when on bumpy dirt roads.
Question:
For those who installed transmission skid plates. Have you seen an increase in transmission temperatures?
Has anyone thermal wrapped the crossover exhaust pipe to reduce heat near the transmission?
I doubt you would hit the transmission on bumpy dirt roads, and even if you did it probably wouldn't do much damage its not like you're sliding over a rock.
Do you have a transmission cooler? If so along with the aluminum pan, you're fine.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
